NIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here.
As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builder to generate a simple system with mainly NIOSII/f and one HPCII DDR2 controller. The controller is running full rate which means the "local width" is 64 bits. The DDR2 size is 256MB so the span is 0x10000000 (bytes) and the base address is 0x20000000 in SOPC. I am trying to confirm how to access all of the memory. Should I use IOWR/IORD or IOWR_32DIRECT/IORD_32DIRECT? If I use IOWR_32DIRECT/IORD_32DIRECT then should I read/write as: IOWR_32DIRECT(BASE, 0, val); IOWR_32DIRECT(BASE, 4, val); IOWR_32DIRECT(BASE, 8, val); ... IOWR_32DIRECT(BASE, 0xFFFFFFC, val); else should the address increments be multiples of 8. Else what? Thank-you.27 Replies
There appears to be a somewhat similar thread at:
http://www.alterauserforums.org/forum/showthread.php?t=24132 with title: "DDR SDRA IP local address" where BadOmen helped out another poor soul. Difference here is that I am using a fully enclosed SOPC system where all code is generated by the tools which I shouldn't have to touch. Help. :) - Altera_Forum
Can you copy your test code into this post just to make sure it's not a software issue. Also when you say that you dropped the clock speed down to 50MHz, you left the SDRAM operating at a faster clock speed correct? DDR-SDRAM has a minimum clock frequency of 77MHz if I remember correctly, DDR2-SDRAM minimum frequency is 125MHz I think.
Also I still highly recommend simulating this design, it'll show you what the accesses look like on the fabric and will not be affected by timing issues. The Nios II software will get pulled into the simulation so there isn't much you have to do besides run a macro or two in Modelsim before starting the simulation. - Altera_Forum
Thank-you for the reply.
Will attach the code. Code will eventually be for two 32 bit devices so there are a few small hacks related to this but otherwise fairly clean code. Code is a c file but changed to .txt for upload. >>>>Also when you say that you dropped the clock speed down to 50MHz, you left the >>>>SDRAM operating at a faster clock speed correct? DDR-SDRAM has a minimum clock >>>>frequency of 77MHz if I remember correctly, DDR2-SDRAM minimum frequency is >>>>125MHz I think. DDR2 is still running at 200MHz. I will take a look simulating this. Regards. - Altera_Forum
Your 'test_addr' goes 1, 2, 4, 8, 16, 32, 64, 128 ,etc... This doesn't seem to match the output that you showed above where the address just increments four or eight bytes at a time. I think you meant to write 1, 2, 4, 8, 16, etc... as the data but only move four/eight bytes at a time.
This is the line(s) I'm talking about: test_addr = 8 * (1 << i); - Altera_Forum
For the output above where the address just increments four or eight bytes at a time:
this is output from the function ddr_test_fulldata() so test_addr = 8*i (ie. 0x0,0x8,0x10,0x18, etc) which matches the 8x address incrementing above for ddr_test_fulldata(). For test_addr = 8 * (1 << i); we have 1 shifting left i times and then multiply by 8 (ie. 0x8, 0x10,0x20,0x40, etc). >>>Your 'test_addr' goes 1, 2, 4, 8, 16, 32, 64, 128 ,etc... I am not sure where this is coming from. :( The output was: 1: wrote 00000001, test_addr 00000000, read_val 00000001, device 0 2: wrote 00000002, test_addr 00000008, read_val 00000002, device 0 3: wrote 00000004, test_addr 00000010, read_val 00000004, device 0 4: wrote 00000008, test_addr 00000018, read_val 00000008, device 0 5: wrote 00000010, test_addr 00000020, read_val 00000010, device 0 yadda, yadda. Perhaps my awkward reporting order/style of: wrote_val:test_addr:read_val is confusing. ie. test_addr is not the first column(it is the middle column). Sorry if I have not been clear. - Altera_Forum
Thinking out loud here but assuming there is an issue with the system SOPC
is generating then I wonder if increasing the column address width by 1 would help. Then access as 8x and my span would be twice so I could see all the memory. Downside would be that more SOPC span is lost but that would be ok. ?? - Altera_Forum
Ok, I started an SR with Altera and they said:
>>When NIOS II (32 bit Master) is trying to access your memory controller (64 bit slave), >>Master Byte Address will need to be at incremental of 8. >>Could you please refer to Avalon Interface specification document for better >>explaination. http://www.altera.com/literature/manual/mnl_avalon_spec.pdf >>Table 3-3 >>Such incremental step is required for Avalon bus interfacing between NIOS-II and your >>memory controller local bus, and it is not related with memory burst length setting >>(x4 or x8) in memory controller. So, this confirms my suspicion and experiments that the address needs to increment by 8. But note you still only get 4 bytes of data per address increment of 8. In the same SR update I had asked two other questions which did not get answers (common with Altera SR feedback depending on the support individual): 1) ie. how do I access ____ALL____ 256MB of this device. 2) Does this mean we ____WILL____ only see half of our memory??? So, the span generated is 0x10000000 for 256MB DDR and I thus cannot access past this span and thus with address increments of 8 I will only see half the memory and would need a span twice this size to see it all. No? Else how do I see all the mem. Thoughts? Regards. - Altera_Forum
Still no resolution to this :(
Here is some more data... (sorry about the screwed up formatting in the table here) For writes(B = byte, L = local): ACCESS BADDR BDATA LADDR BE WDATA 1 0 1 0 0F 0000000100000001h 2 4 2 0 F0 0000000200000002h 3 8 4 1 0F 0000000400000004h 4 c 8 1 F0 0000000800000008h 5 10 10 2 0F 0000001000000010h 6 14 20 2 F0 0000002000000020h ... Behavior for reads is same but at the time of local_rdata_valid the data on local_rdata is: ACCESS local_rdata 1 0000000400000004h 2 0000000400000004h 3 0000000800000008h 4 0000000800000008h 5 0000004000000040h 6 0000004000000040h ... For all these: local_size = 1 Clearly not a fabric issue. Issue must reside in controller(and/or the way it is configured) or in my hardware. From here on I will only test with x4 addressing. Currently, I am doing all the writes and then all the reads but if I do the writes and reads back to back then it works ... temporarily. ie. if I go write,write,write,... then read,read,read,... then no good if I go write,read,write,read, ... then ok (until I read 'em all after this) So, it would seem that subsequent writes are stepping on the previous writes. When I do x8 accesses BE is always 0x0F and when I do x4 accesses then BE alternates between 0x0F and 0xF0 as expected and I think it is when I mix these two types of accesses that things go awry. If I do x8 accesses starting at addr 0(ie. 0,8,0x10,0x18, etc) then _nothing_ gets stomped on. If I do x8 accesses starting at addr 4(ie. 0,4,0xC,0x14, etc) then _nothing_ gets stomped on. However, it is when I do writes where some use BE 0x0F and others use BE 0xF0 then that is when things go awry. I will clarify for you how the hardward is hooked up: o I have two 16 bit DDR2 devices. o The same address bus goes to both DDR A0-A12 o The same BA goes to both DDR BA0-BA2 o The same CK/CK# go to both DDR CK/CK# o The same CS,WE,RAS,CAS go to both o DQS0,1 go to device 0 LDQS,UDQS and DQS2,3 go to device 1 LDQS,UDQS o ODT is also shared o DQ0-15 go to device 0, DQ16-31 go to device 1. o LDM,UDM for both devices is grounded through a resistor. Of course, the controller is configured as a 32 bit single device with 1 CS, 8 DQ per DQS, drive DM pins=NO, 1 output clk pair. Thanks. - Altera_Forum
Devices I am using are MT47H64M16
Configuration: 8 Meg x 16bit x 8 banks (ie. 1Gb, 128MB, or 64M x 16bit locations) Row Addr: A[12:0] (8K) Bank Addr: BA[2:0] (8) Col Addr: A[9:0] (1K) Total of row/bank/col = 8Kx8x1K = 64M x 16bit locations(according to the datasheet). Now, given the way I have connected the two devices we still have the same number of locations but now the density doubles since the number of DQ's has doubled. In order to access every location I need access to all address locations (row,bank,col) but the datasheet for the controller says for its example: >>>>>local_address[23:11] = row address[12:0] >>>>>local_address[10:9] = bank address [1:0] >>>>>local_address [8:0] = column address[9:1] >>>>>The least significant bit (LSB) of the column address (multiples of four) on >>>>>the memory side is ignored, because the local data width is twice that of the >>>>>memory data bus width. Is it not true that I need to be able to toggle the LSB of the column address to access all the memory? To me it would seem absolutely necessary. With consideration to my previous post: I am trying to understand how the given accesses show up on the mem side. The datasheet is does not really cover my case clearly with the aid of timing diagrams. Here was the data in question: For writes(B = byte, L = local): ACCESS BADDR BDATA LADDR BE WDATA 1 0 1 0 0F 0000000100000001h 2 4 2 0 F0 0000000200000002h 3 8 4 1 0F 0000000400000004h 4 c 8 1 F0 0000000800000008h 5 10 10 2 0F 0000001000000010h 6 14 20 2 F0 0000002000000020h ... I would imagine that all of these would be single 32 bit accesses to the memory(which is 32 bits wide) and thus from one cycle to another the only things that should change would be the mem_DQ's and the mem_addr. I would expect all other signals to behave the same (until bank end is reached) so on the mem interface things should not look different whether BE is 0x0F or 0xF0 but something is definitely not functioning correctly here. It is my contention that there are bugs in the controller for how varying BE transfers are handled. Here is some more data: 1: wrote 00000001, test_addr 00000000, read_val fffffffe, device 1 2: wrote 00000002, test_addr 00000008, read_val fffffffd, device 1 3: wrote 00000004, test_addr 00000010, read_val fffffffb, device 1 4: wrote 00000008, test_addr 00000018, read_val fffffff7, device 1 5: wrote fffffffe, test_addr 00000004, read_val fffffffe, device 1 6: wrote fffffffd, test_addr 0000000c, read_val fffffffd, device 1 7: wrote fffffffb, test_addr 00000014, read_val fffffffb, device 1 8: wrote fffffff7, test_addr 0000001c, read_val fffffff7, device 1 For this test I wanted to see what would happen to four BE=0x0F (x8) writes if I followed them with four BE=0xF0 (x8 but with offset 4 addrs). Here I do the 8 writes and then read them back at the end in the order they were written. Sure enough the data from 1-4 get stomped on by the writes 5-8. If I read 1-4 back before the 5-8 writes then all is good. It is almost as if the local_be(byte enables) are being completely ignored by the controller. For all accesses, local_size is 1 and local_burstbegin toggles for one cycle with the local_write_req. I welcome any feedback. Thank-you. - Altera_Forum
Hmmm, I wonder if accesses were made to be 64 bit on the local bus which means
that it would use local_be = 0xFF. I wonder if that would work. Perhaps using one of the DMA controllers. What's the easiest way to test this theory?
