16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoStill no resolution to this :(
Here is some more data... (sorry about the screwed up formatting in the table here) For writes(B = byte, L = local): ACCESS BADDR BDATA LADDR BE WDATA 1 0 1 0 0F 0000000100000001h 2 4 2 0 F0 0000000200000002h 3 8 4 1 0F 0000000400000004h 4 c 8 1 F0 0000000800000008h 5 10 10 2 0F 0000001000000010h 6 14 20 2 F0 0000002000000020h ... Behavior for reads is same but at the time of local_rdata_valid the data on local_rdata is: ACCESS local_rdata 1 0000000400000004h 2 0000000400000004h 3 0000000800000008h 4 0000000800000008h 5 0000004000000040h 6 0000004000000040h ... For all these: local_size = 1 Clearly not a fabric issue. Issue must reside in controller(and/or the way it is configured) or in my hardware. From here on I will only test with x4 addressing. Currently, I am doing all the writes and then all the reads but if I do the writes and reads back to back then it works ... temporarily. ie. if I go write,write,write,... then read,read,read,... then no good if I go write,read,write,read, ... then ok (until I read 'em all after this) So, it would seem that subsequent writes are stepping on the previous writes. When I do x8 accesses BE is always 0x0F and when I do x4 accesses then BE alternates between 0x0F and 0xF0 as expected and I think it is when I mix these two types of accesses that things go awry. If I do x8 accesses starting at addr 0(ie. 0,8,0x10,0x18, etc) then _nothing_ gets stomped on. If I do x8 accesses starting at addr 4(ie. 0,4,0xC,0x14, etc) then _nothing_ gets stomped on. However, it is when I do writes where some use BE 0x0F and others use BE 0xF0 then that is when things go awry. I will clarify for you how the hardward is hooked up: o I have two 16 bit DDR2 devices. o The same address bus goes to both DDR A0-A12 o The same BA goes to both DDR BA0-BA2 o The same CK/CK# go to both DDR CK/CK# o The same CS,WE,RAS,CAS go to both o DQS0,1 go to device 0 LDQS,UDQS and DQS2,3 go to device 1 LDQS,UDQS o ODT is also shared o DQ0-15 go to device 0, DQ16-31 go to device 1. o LDM,UDM for both devices is grounded through a resistor. Of course, the controller is configured as a 32 bit single device with 1 CS, 8 DQ per DQS, drive DM pins=NO, 1 output clk pair. Thanks.
