16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoOk, I started an SR with Altera and they said:
>>When NIOS II (32 bit Master) is trying to access your memory controller (64 bit slave), >>Master Byte Address will need to be at incremental of 8. >>Could you please refer to Avalon Interface specification document for better >>explaination. http://www.altera.com/literature/manual/mnl_avalon_spec.pdf >>Table 3-3 >>Such incremental step is required for Avalon bus interfacing between NIOS-II and your >>memory controller local bus, and it is not related with memory burst length setting >>(x4 or x8) in memory controller. So, this confirms my suspicion and experiments that the address needs to increment by 8. But note you still only get 4 bytes of data per address increment of 8. In the same SR update I had asked two other questions which did not get answers (common with Altera SR feedback depending on the support individual): 1) ie. how do I access ____ALL____ 256MB of this device. 2) Does this mean we ____WILL____ only see half of our memory??? So, the span generated is 0x10000000 for 256MB DDR and I thus cannot access past this span and thus with address increments of 8 I will only see half the memory and would need a span twice this size to see it all. No? Else how do I see all the mem. Thoughts? Regards.
