16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoFor the output above where the address just increments four or eight bytes at a time:
this is output from the function ddr_test_fulldata() so test_addr = 8*i (ie. 0x0,0x8,0x10,0x18, etc) which matches the 8x address incrementing above for ddr_test_fulldata(). For test_addr = 8 * (1 << i); we have 1 shifting left i times and then multiply by 8 (ie. 0x8, 0x10,0x20,0x40, etc). >>>Your 'test_addr' goes 1, 2, 4, 8, 16, 32, 64, 128 ,etc... I am not sure where this is coming from. :( The output was: 1: wrote 00000001, test_addr 00000000, read_val 00000001, device 0 2: wrote 00000002, test_addr 00000008, read_val 00000002, device 0 3: wrote 00000004, test_addr 00000010, read_val 00000004, device 0 4: wrote 00000008, test_addr 00000018, read_val 00000008, device 0 5: wrote 00000010, test_addr 00000020, read_val 00000010, device 0 yadda, yadda. Perhaps my awkward reporting order/style of: wrote_val:test_addr:read_val is confusing. ie. test_addr is not the first column(it is the middle column). Sorry if I have not been clear.
