16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoDevices I am using are MT47H64M16
Configuration: 8 Meg x 16bit x 8 banks (ie. 1Gb, 128MB, or 64M x 16bit locations) Row Addr: A[12:0] (8K) Bank Addr: BA[2:0] (8) Col Addr: A[9:0] (1K) Total of row/bank/col = 8Kx8x1K = 64M x 16bit locations(according to the datasheet). Now, given the way I have connected the two devices we still have the same number of locations but now the density doubles since the number of DQ's has doubled. In order to access every location I need access to all address locations (row,bank,col) but the datasheet for the controller says for its example: >>>>>local_address[23:11] = row address[12:0] >>>>>local_address[10:9] = bank address [1:0] >>>>>local_address [8:0] = column address[9:1] >>>>>The least significant bit (LSB) of the column address (multiples of four) on >>>>>the memory side is ignored, because the local data width is twice that of the >>>>>memory data bus width. Is it not true that I need to be able to toggle the LSB of the column address to access all the memory? To me it would seem absolutely necessary. With consideration to my previous post: I am trying to understand how the given accesses show up on the mem side. The datasheet is does not really cover my case clearly with the aid of timing diagrams. Here was the data in question: For writes(B = byte, L = local): ACCESS BADDR BDATA LADDR BE WDATA 1 0 1 0 0F 0000000100000001h 2 4 2 0 F0 0000000200000002h 3 8 4 1 0F 0000000400000004h 4 c 8 1 F0 0000000800000008h 5 10 10 2 0F 0000001000000010h 6 14 20 2 F0 0000002000000020h ... I would imagine that all of these would be single 32 bit accesses to the memory(which is 32 bits wide) and thus from one cycle to another the only things that should change would be the mem_DQ's and the mem_addr. I would expect all other signals to behave the same (until bank end is reached) so on the mem interface things should not look different whether BE is 0x0F or 0xF0 but something is definitely not functioning correctly here. It is my contention that there are bugs in the controller for how varying BE transfers are handled. Here is some more data: 1: wrote 00000001, test_addr 00000000, read_val fffffffe, device 1 2: wrote 00000002, test_addr 00000008, read_val fffffffd, device 1 3: wrote 00000004, test_addr 00000010, read_val fffffffb, device 1 4: wrote 00000008, test_addr 00000018, read_val fffffff7, device 1 5: wrote fffffffe, test_addr 00000004, read_val fffffffe, device 1 6: wrote fffffffd, test_addr 0000000c, read_val fffffffd, device 1 7: wrote fffffffb, test_addr 00000014, read_val fffffffb, device 1 8: wrote fffffff7, test_addr 0000001c, read_val fffffff7, device 1 For this test I wanted to see what would happen to four BE=0x0F (x8) writes if I followed them with four BE=0xF0 (x8 but with offset 4 addrs). Here I do the 8 writes and then read them back at the end in the order they were written. Sure enough the data from 1-4 get stomped on by the writes 5-8. If I read 1-4 back before the 5-8 writes then all is good. It is almost as if the local_be(byte enables) are being completely ignored by the controller. For all accesses, local_size is 1 and local_burstbegin toggles for one cycle with the local_write_req. I welcome any feedback. Thank-you.
