15 years ago
Nios II/f performance on Cyclone IV E
I am trying to evaluate Nios II/f on a dev. board fitted with
EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios
II Hardware Design Example) to my board. Design specs are:
* Nios II/f, 4 Kbytes i-cache, 2 Kbytes d-cache
* System clock: 140MHz
* JTAG debug module: Yes
* On-chip RAM: 64 Kbytes
* JTAG UART: 1
* Timer: 1
I've kept the settings, clock, build flags etc. same as in original example. When
running the dhrystone example I get:
Microseconds for one run through Dhrystone: 6.5
Dhrystones per Second: 153506.9
VAX MIPS rating = 87.369
This is way less than what the attached readme.txt states:
...This system achieves over 150 DMIPS on the Cyclone III FPGA Development Kit,
and can achieve over 190 DMIPS when targeting the fastest speed grade of a
CycloneIII device...
According to ds_nios2_perf.pdf MIPS/MHz ratio of Cyclone IV GX is the same as
Cyclone III LS and a bit higher than Cyclone III. Regardless of that MIPS != DMISP
I can't imagine such DMIPS/MHz ratio difference between Cyclone IV and III. Or
am I missing some difference with Nios2 between Cyclone IV GX and E?
Can somebody shed some light on this?
Thanks for your help.
