15 years agoNios II/f performance on Cyclone IV E
Hi, I am trying to evaluate Nios II/f on a dev. board fitted with EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios II Hardware Design Example) to my board....
15 years agoSOPC system layout is exactly the same as their (Altera) CycloneIII design
example which (they say) achieves over 150 DMIPS clocked at 140MHz. Dhrystone app has a set of build scripts carefully specifying how to (or rather not to) optimize the code. HW multiplier is build with embedded multipliers, all code runs from internal RAM (dual port - one to instruction and other to data master). I've also tested running the same code from SDRAM - 41 DMIPS at 100MHz. I get the same result on another design on which I run uClinux with included dhrystone (different compiler, different program - but same dhrystone 2.1 codebase). There is an old post about NiosII/f dhrystone on Cyclone EP1C20F400C7. The author got 35 DMIPS at 50 MHz and Cyclone I doesn't even have embedded multipliers. I get 31 DMIPS as 50 MHz...
