15 years agoNios II/f performance on Cyclone IV E
Hi, I am trying to evaluate Nios II/f on a dev. board fitted with EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios II Hardware Design Example) to my board....
13 years agoApplication makefile created by Nios2 sw build tools should contain APP_CFLAGS_OPTIMIZATION, set it to
-O2 or -O3..6. Changing BSP optimization flags can be done by passing --set hal.make.bsp_cflags_optimization -O2 to nios2-bsp. You chould check Nios2 Software Build Tools documentation for more. On a side note you might wan't to check the newly released sourcery gcc 4.7.3. I've found it generates much better - faster - code in some cases than the old gcc from Altera. But beware it has some serious issues with custom floating point instructions.
