15 years agoNios II/f performance on Cyclone IV E
Hi, I am trying to evaluate Nios II/f on a dev. board fitted with EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios II Hardware Design Example) to my board....
15 years agoThanks for the info. The problem seems to be in the compiler - dhrystone test compiled
with gcc 4.1.2 estimates 0.62 DMIPS/MHz and with gcc 3.4.6 1.04 DMIPS/MHz. It doesn't matter which version was used to compile the BSP, just the dhrystone itself. I've used the same makefile / compiler flags, but changing e.g. optimization level doesn't yield much difference with 4.1.2. I didn't investigate this any further, but obviously it's something to keep in mind.
