15 years agoNios II/f performance on Cyclone IV E
Hi, I am trying to evaluate Nios II/f on a dev. board fitted with EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios II Hardware Design Example) to my board....
15 years agoTry the following changes to the gcc sources, the 2nd may be relevant.
gcc/config/nios2/nios2.h may need some changes undone/fixed: 1) Change the value of JUMP_TABLES_IN_TEXT_SECTION from "1" to "flag_pic". 2) Remove "!SYMBOL_REF_EXTERNAL_P(RTX) &&" from the definition of SYMBOL_REF_IN_NIOS2_SMALL_DATA_P(RTX). From http://www.alterawiki.com/wiki/crossgcc see also http://www.alterawiki.com/wiki/gcc_patches which may improve the code for both versions of gcc.
