15 years agoNios II/f performance on Cyclone IV E
Hi, I am trying to evaluate Nios II/f on a dev. board fitted with EP4CE55F23C7. I've ported the Cyclone III Dhrystone example from Altera (Fast Nios II Hardware Design Example) to my board....
15 years agoI did try compiling my code with gcc4, my static analysis showed the code to both larger and slower than that generated by gcc3. I didn't look to see why.
(That code is rather carefully crafted to avoid anything on-stack.) That would have been after I'd applied my changes to the gcc4 code generator and reversed some of Altera's changes. I'm also surprised that changing the optimisation level had little/no effect. The difference between -O0 and -O2 should be massive.
