20 years agoHow to build u-boot for cycloneII board?
Hi all,
Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. Thanks in advance.11 Replies
Hi posix6973,
> Can someone tell me the procedure to build u-boot for owner niosII board? I'm not familiar with the owner niosII board -- you will need to add support for this board in the u-boot source tree. > I need u-boot to use it in Altera niosII development kit CycloeII edition and > owner design CycloneII board. You will need to add support for these boards. Please read the top-level README -- especially the section "Building the Software." For the Altera Cyclone II board, you can use any of the existing Altera boards as a starting point (e.g.: board/altera/ep1c20). Regards, --Scott - Altera_Forum
Hi smcnutt,
According to the EP1C20 I have built the u-boot and succeed in download boot up the Altera cyclone II board but I got CRC error report in console. I have no ideal about this error could you explain this? U-Boot 1.1.3 (Sep 26 2005 - 14:10:12) CPU : Nios-II SYSID : 6163a3b2, Sat Sep 24 09:50:31 2005 BOARD : Altera EP-2C35 *** Warning - bad CRC, using default environment ==> ==> Another question, How to add Ethernet driver to support DM9000 MAC? Thanks. - Altera_Forum
Hi posix6973,
> *** Warning - bad CRC, using default environment Your environment has a bad CRC. Until you save the environment to non-volatile memory u-boot will detect an invalid environment and use the default environment (which is defined at compile time). For the EP1C20, the environment is stored at 0x0004_0000 (flash: CFG_ENV_ADDR). Please read the top-level README ... it contains alot of useful information. You can simply search for " _ENV_" to review environment information. > How to add Ethernet driver to support DM9000 MAC Remove the SMC driver macros (e.g. CONFIG_SMC91111_BASE) and define CONFIG_DRIVER_DM9000 ... and other CONFIG_DM9000_xxx macros as needed. Regards, --Scott - Altera_Forum
Hi smcnutt,
I have built u-boot with DM9000 support and succeed download to Microtronix ukit board and boot up but it seems don¡¦t recognize the DM9000 MAC. Below is my board configuration: /*------------------------------------------------------------------------ * ETHERNET -- The header file for the DM9000 *----------------------------------------------------------------------*/ # define CONFIG_DRIVER_DM9000 1# define CONFIG_DM9000_BASE 0x00000000# define DM9000_IO CONFIG_DM9000_BASE# define DM9000_DATA (CONFIG_DM9000_BASE+4)# define CONFIG_DM9000_USE_16BIT # define CONFIG_ETHADDR 08:00:3e:26:0a:5b# define CONFIG_NETMASK 255.255.255.0# define CONFIG_IPADDR 192.168.14.123# define CONFIG_SERVERIP 192.168.14.32 u-boot: Console report U-Boot 1.1.3 (Sep 27 2005 - 16:20:50) CPU : Nios-II SYSID : a4a90077, Thu Jan 01 00:00:00 1970 BOARD : Microtronix_ukit *** Warning - bad CRC, using default environment ==> printenv baudrate=115200 ethaddr=08:00:3e:26:0a:5b ipaddr=192.168.14.123 serverip=192.168.14.32 netmask=255.255.255.0 stdin=serial stdout=serial stderr=serial Environment size: 150/65532 bytes ==> ping 192.168.14.32 dm9000 not found at 0x00000000 id: 0x01010101 MAC: 00:00:00:00:00:00 could not establish link *** ERROR: `ethaddr' not set ping failed; host 192.168.14.32 is not alive ==> md 0 00000000: 00010005 00000000 00000000 00000000 ................ 00000010: 00000000 000005f2 00000000 00000000 ................ 00000020: 00000000 00000000 00000000 00000000 ................ 00000030: 00000000 00000000 00000000 00000000 ................ 00000040: 00000001 00000000 00000000 00000000 ................ 00000050: 00000000 00000000 00000000 00000000 ................ 00000060: 00000000 00000000 00000000 00000000 ................ 00000070: 00000000 00000000 00000000 00000000 ................ 00000080: 00000000 00000000 00000000 00000000 ................ 00000090: 00000000 00000000 00000000 00000000 ................ 000000a0: 00000000 00000000 00000000 00000000 ................ 000000b0: 00000000 00000000 00000000 00000000 ................ 000000c0: 00000000 00000000 00000000 00000000 ................ 000000d0: 00000000 00000000 00000000 00000000 ................ 000000e0: 00000004 00000200 00000000 00000000 ................ 000000f0: 00000000 00000000 00000000 00000000 ................ ==> Would you please check it for me and thanks for help. Thanks Again. Regards, - Altera_Forum
Hi posix6973,
> I have built u-boot with DM9000 support and succeed download to Microtronix ukit board Did you add the DM9000 to the ukit board? As I recall, the ukit assumes a MAC implemented in the FPGA (it has an external PHY, but no external MAC). If you added your own DM9000 via an expansion header, you should check your hardware interface. > Would you please check it for me and thanks for help. I'm not sure what you would like me to check. If the code you are attempting to use does not work, it's generally a good idea to review it. Did you read through the probe routine? If not, I strongly recommend that you do so. Regards, --Scott - Altera_Forum
Hi smcnutt,
Sorry, my mistake I take the wrong SOF file. The u-boot can find the DM9000 now but the NET seems work incorrect. U-Boot 1.1.3 (Sep 28 2005 - 11:12:54) CPU : Nios-II SYSID : a98ca823, Fri Sep 23 08:13:59 2005 BOARD : Microtronix_ukit *** Warning - bad CRC, using default environment ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: ff:ff:ff:ff:ff:ff operating at 100M full duplex mode host 192.168.14.32 is alive ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: 00:00:00:00:00:00 operating at 100M full duplex mode *** ERROR: `ethaddr' not set ping failed; host 192.168.14.32 is not alive ==> I think it is DM9000 head file setting incorrect. If so how to correct? Please help. # define CONFIG_DRIVER_DM9000 1# define CONFIG_DM9000_BASE 0x80000000# define DM9000_IO CONFIG_DM9000_BASE# define DM9000_DATA (CONFIG_DM9000_BASE+4)# define CONFIG_DM9000_USE_16BIT # define CONFIG_ETHADDR 08:00:3e:26:0a:5b# define CONFIG_NETMASK 255.255.255.0# define CONFIG_IPADDR 192.168.14.123# define CONFIG_SERVERIP 192.168.14.32 Regards, - Altera_Forum
Hi posix6973,
<div class='quotetop'>QUOTE </div> --- Quote Start --- ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: ff:ff:ff:ff:ff:ff operating at 100M full duplex mode host 192.168.14.32 is alive ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: 00:00:00:00:00:00 operating at 100M full duplex mode *** ERROR: `ethaddr' not set[/b] --- Quote End --- Your MAC address is getting trashed -- which probably means your board info structure is being corrupted, which means the global data structure is probably being corrupted -- which can lead to many other potential problems as well. You should probably check the following macros to make sure you have them set correctly: CFG_MALLOC_BASE CFG_GBL_DATA_OFFSET CFG_INIT_SP Check the board info structure after reset (with the bdi command), try ping, then check the board info structure again to see if the data is actually being corrupted. Regards, --Scott - Altera_Forum
Hi Scott,
Yes, you right the board info structure is actually being corrupt after execute ping command: U-Boot 1.1.3 (Sep 29 2005 - 14:51:23) CPU : Nios-II SYSID : a98ca823, Fri Sep 23 08:13:59 2005 BOARD : Microtronix_ukit *** Warning - bad CRC, using default environment ==> bdi mem start = 0x01000000 mem size = 0x01000000 flash start = 0x00800000 flash size = 0x00800000 flash offset= 0x00000000 ethaddr = 08:00:3E:26:0A:5B ip_addr = 192.168.14.123 baudrate = 115200 bps ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: 00:00:00:00:00:00 operating at 100M half duplex mode *** ERROR: `ethaddr' not set ping failed; host 192.168.14.32 is not alive ==> bdi mem start = 0x01000000 mem size = 0x01000000 flash start = 0x00800000 flash size = 0x00800000 flash offset= 0x00000000 ethaddr = 00:00:00:00:00:00 ip_addr = 192.168.14.123 baudrate = 0 bps ==> What can I do now? My board configuration is set as: TEXT_BASE = 0x018C0000 /*------------------------------------------------------------------------ * MEMORY ORGANIZATION * -Monitor at top. * -The heap is placed below the monitor. * -Global data is placed below the heap. * -The stack is placed below global data (&grows down). *----------------------------------------------------------------------*/# define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256k */# define CFG_GBL_DATA_SIZE 128 /* Global data size rsvd*/# define CFG_MALLOC_LEN (CFG_ENV_SIZE + 256*1024) /* 256k heap */ # define CFG_MONITOR_BASE TEXT_BASE# define CFG_MALLOC_BASE (CFG_MONITOR_BASE - CFG_MALLOC_LEN)# define CFG_GBL_DATA_OFFSET (CFG_MALLOC_BASE - CFG_GBL_DATA_SIZE)# define CFG_INIT_SP CFG_GBL_DATA_OFFSET Thanks, Best regards, - Altera_Forum
Hi posix6973,
Ok, I think I found the problem ... but I have no way of testing since I don't have a board with a DM9000 ... so I'll leave that up to you ;-). The problem is in dm9000.c, eth_init routine, starting at line 303:<div class='quotetop'>QUOTE </div> --- Quote Start --- for (i = 0; i < 6; i++) ((u16 *) bd->bi_enetaddr) = read_srom_word(i);printf("mac: %02x:%02x:%02x:%02x:%02x:%02x\n", bd->bi_enetaddr[0],
bd->bi_enetaddr[1], bd->bi_enetaddr[2], bd->bi_enetaddr[3],
bd->bi_enetaddr[4], bd->bi_enetaddr[5]);
for (i = 0, oft = 0x10; i < 6; i++, oft++)
dm9000_iow(oft, bd->bi_enetaddr); for (i = 0, oft = 0x16; i < 8; i++, oft++) DM9000_iow(oft, 0xff);[/b] --- Quote End --- This is pretty brain-damaged ... and also explains why the baudrate gets corrupted as well ... as the 16-bit writes spill over into the baudrate field of the board info struct. You have a few choices here: 1. If you're not using an eeprom with your DM9000, just remove the for statement -- the driver should not be copying the MAC address into the bd struct if there is no eeprom anyway. 2. If you are using an eeprom, you will have to rewrite the code to unpack the 16-bit values into the bd struct. Maybe something like the following will do:<div class='quotetop'>QUOTE </div> --- Quote Start --- for (i = 0; i < 3; i++) { u16 val = read_srom_word (i); bd->bi_enetaddr)[(i<<1)] = val >>8 bd->bi_enetaddr)[(i<<1)+1] = val & 0x0ff; }[/b] --- Quote End --- You will, of course, have to decide if the eeprom MAC address, or the environment MAC address (if present) should be used. In general, if the user programs a MAC address (ethaddr) into the environment (which is copied into the bd struct at startup), it should be used. If the user wants to use the eeprom MAC address, the ethaddr env variable should not be defined. Based on the output you posted, you don't have an eeprom (or it is not programmed). Regardless, a patch should be submitted to the u-boot project. If you need help with this just contact me via email. Regards, --Scott
Hi Scott,
As you mentioned I removed the line 303 from dm9000x.c the board info structure not corrupted again. But, The NET seems can ping out only that is when issue ping command the dm9000 LINKACT# pin light up and light off after executed command then the Ethernet is broken so I can not ping it form outside. Would you please help me to patch the dm9000x.c file? Thanks, Best regards, Email: [email protected]
