20 years agoHow to build u-boot for cycloneII board?
Hi all, Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. T...
20 years agoHi Scott,
As you mentioned I removed the line 303 from dm9000x.c the board info structure not corrupted again. But, The NET seems can ping out only that is when issue ping command the dm9000 LINKACT# pin light up and light off after executed command then the Ethernet is broken so I can not ping it form outside. Would you please help me to patch the dm9000x.c file? Thanks, Best regards, Email: [email protected]
