20 years agoHow to build u-boot for cycloneII board?
Hi all, Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. T...
20 years agoHi posix6973,
> I have built u-boot with DM9000 support and succeed download to Microtronix ukit board Did you add the DM9000 to the ukit board? As I recall, the ukit assumes a MAC implemented in the FPGA (it has an external PHY, but no external MAC). If you added your own DM9000 via an expansion header, you should check your hardware interface. > Would you please check it for me and thanks for help. I'm not sure what you would like me to check. If the code you are attempting to use does not work, it's generally a good idea to review it. Did you read through the probe routine? If not, I strongly recommend that you do so. Regards, --Scott
