20 years agoHow to build u-boot for cycloneII board?
Hi all, Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. T...
20 years agoHi posix6973,
<div class='quotetop'>QUOTE </div> --- Quote Start --- ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: ff:ff:ff:ff:ff:ff operating at 100M full duplex mode host 192.168.14.32 is alive ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: 00:00:00:00:00:00 operating at 100M full duplex mode *** ERROR: `ethaddr' not set[/b] --- Quote End --- Your MAC address is getting trashed -- which probably means your board info structure is being corrupted, which means the global data structure is probably being corrupted -- which can lead to many other potential problems as well. You should probably check the following macros to make sure you have them set correctly: CFG_MALLOC_BASE CFG_GBL_DATA_OFFSET CFG_INIT_SP Check the board info structure after reset (with the bdi command), try ping, then check the board info structure again to see if the data is actually being corrupted. Regards, --Scott
