20 years agoHow to build u-boot for cycloneII board?
Hi all, Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. T...
20 years agoHi Scott,
Yes, you right the board info structure is actually being corrupt after execute ping command: U-Boot 1.1.3 (Sep 29 2005 - 14:51:23) CPU : Nios-II SYSID : a98ca823, Fri Sep 23 08:13:59 2005 BOARD : Microtronix_ukit *** Warning - bad CRC, using default environment ==> bdi mem start = 0x01000000 mem size = 0x01000000 flash start = 0x00800000 flash size = 0x00800000 flash offset= 0x00000000 ethaddr = 08:00:3E:26:0A:5B ip_addr = 192.168.14.123 baudrate = 115200 bps ==> ping 192.168.14.32 dm9000 i/o: 0x80000000, id: 0x90000a46 MAC: 00:00:00:00:00:00 operating at 100M half duplex mode *** ERROR: `ethaddr' not set ping failed; host 192.168.14.32 is not alive ==> bdi mem start = 0x01000000 mem size = 0x01000000 flash start = 0x00800000 flash size = 0x00800000 flash offset= 0x00000000 ethaddr = 00:00:00:00:00:00 ip_addr = 192.168.14.123 baudrate = 0 bps ==> What can I do now? My board configuration is set as: TEXT_BASE = 0x018C0000 /*------------------------------------------------------------------------ * MEMORY ORGANIZATION * -Monitor at top. * -The heap is placed below the monitor. * -Global data is placed below the heap. * -The stack is placed below global data (&grows down). *----------------------------------------------------------------------*/# define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256k */# define CFG_GBL_DATA_SIZE 128 /* Global data size rsvd*/# define CFG_MALLOC_LEN (CFG_ENV_SIZE + 256*1024) /* 256k heap */ # define CFG_MONITOR_BASE TEXT_BASE# define CFG_MALLOC_BASE (CFG_MONITOR_BASE - CFG_MALLOC_LEN)# define CFG_GBL_DATA_OFFSET (CFG_MALLOC_BASE - CFG_GBL_DATA_SIZE)# define CFG_INIT_SP CFG_GBL_DATA_OFFSET Thanks, Best regards,
