20 years agoHow to build u-boot for cycloneII board?
Hi all, Can someone tell me the procedure to build u-boot for owner niosII board? I need u-boot to use it in Altera niosII development kit CycloeII edition and owner design CycloneII board. T...
20 years agoHi posix6973,
> *** Warning - bad CRC, using default environment Your environment has a bad CRC. Until you save the environment to non-volatile memory u-boot will detect an invalid environment and use the default environment (which is defined at compile time). For the EP1C20, the environment is stored at 0x0004_0000 (flash: CFG_ENV_ADDR). Please read the top-level README ... it contains alot of useful information. You can simply search for " _ENV_" to review environment information. > How to add Ethernet driver to support DM9000 MAC Remove the SMC driver macros (e.g. CONFIG_SMC91111_BASE) and define CONFIG_DRIVER_DM9000 ... and other CONFIG_DM9000_xxx macros as needed. Regards, --Scott
