13 years ago
boot NIOS from EPCS flash and use SDRAM to store instructions and data
Hi! In the qsys I have:
1. Clock Source
2. On-Chip Memory
3. Nios II Processor
4. System ID
5. JTAG UART
6. EPCS Serial Flash Controller
7. PIO
8. SDRAM Controller
I want to use SDRAM (MT48LC4M32B2) to store instructions and data for NIOS application. In the NIOS II Processor properties reset vector is set to base address of EPCS controller. Exceptions vector is set to base address to SDRAM. In the NIOS EDS for Eclipce I can debug my application, it works. But in the NIOS flash programmer error occur:
"Error: Error code: 4 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "D:/Work/QuartusProjects/tests/test2/flash/test2_epcs_flash.flash" --base=0x2003800 --epcs --sidp=0x2004010 --id=0x0 --timestamp=1359654107 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program"
What I did wrong? Thank you
