13 years agoboot NIOS from EPCS flash and use SDRAM to store instructions and data
Hi! In the qsys I have: 1. Clock Source 2. On-Chip Memory 3. Nios II Processor 4. System ID 5. JTAG UART 6. EPCS Serial Flash Controller 7. PIO 8. SDRAM Controller I want to use...
13 years agoIf you can debug the firmware whitin the sdram it should work correct. Before debugging the debugger performs a verify of your code stored in the sdram.
The EPCS Controller executes after startup a small piece of code the boot loader. (file your_sopc_epcs_controller_boot_rom_synth.hex in the sopc subdirectories) How does the boot loader know from which EPCS the code should be loaded? Jens
