13 years agoboot NIOS from EPCS flash and use SDRAM to store instructions and data
Hi! In the qsys I have: 1. Clock Source 2. On-Chip Memory 3. Nios II Processor 4. System ID 5. JTAG UART 6. EPCS Serial Flash Controller 7. PIO 8. SDRAM Controller I want to use...
13 years agoanother idea for starting: try at first to put all *.flash (as i described above) in the first EPCS and assign the EPCS controller in qsys to that EPCS. Ignore for bring up your hardware the second EPCS. After you know that this part of your hardware works correct you can start bring up the rest.
