dicas3d's avatar
dicas3d
3 years ago
Verilog .v and.vp on zip file to Qsys
I got a model in Verilog from my development board's SDRAM controller controller manufacturer. The model comes in a file. zip that contains a file. .vp and a .vp file. How to convert to an Qsys component?
  • dicas3d's avatar
    dicas3d
    I think that I need to use modelsim or another simulation software to do the task. Can anyone who knows confirm? I don't tryed yet because just on Monday I have access to the computer with the Quartus prime lite and the project that I'm working.
  • dicas3d's avatar
    dicas3d
    Yes, maybe. But in my particular case I even don't know if I need any key and I'm in doubt if I'm capable of working with the model without NC-Verilog because it's payed. To check it better the model is the provided in link https://www.winbond.com/hq/product/specialty-dram/sdram/?__locale=en&partNo=W9864G6JT . Does Intel Quartus Prime Lite allow precompiled Verilog models to be used as components? If yes, I can try compiling on edaplayground which has NC-Verilog.
  • FvM's avatar
    FvM
    not completely clear what you are trying to achieve. The RAM model is for simulation only. Typically you connect it in the simulation top level (test bench) to your design under test.
    • dicas3d's avatar
      dicas3d
      From what I've researched so far there is no ready IP Core available for QSYS for this SDRAM controller. What I'm trying to do is to solve this. Even the manufacturer sends this when asked about it. So what I'm trying to do is use the model as/convert the model to the IP Core. As I know in Quartus Prime pro we can execute simulation models inside a component to do it called Generic Component.
  • SyafieqS's avatar
    SyafieqS
    Speaking of generic type, you can refer to below doc for more detail. Platform Designer allows you to add generic components with the implementation defined in _hw.tcl (IP type), in an HDL file (HDL type), in high level synthesis files (HLS type), or with only a partially defined implementation (Blackbox type).
    https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/creating-generic-components-in-a-system.html
    I believe this is what you are looking for.
    • dicas3d's avatar
      dicas3d
      This tutorial is only applicable in the pro version, but I managed to get an SDRAM controller working on my system and version ported from an old version.
  • SyafieqS's avatar
    SyafieqS
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
