10 years ago
Problem with VIP suite on Cyclone V device
I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader output , serialize the output and send it to ADV chip using CVO. I'm running the VIP IPs at 27Mhz and the memory read is at 216Mhz.
I tested this flow HPS DDR3->FR->ITL->CVO using the VIP, underflow in CVO output detected with non valid image output.
To check the path error I have put signal tap into the project and suspected Interlacer output.
I tried using test pattern generator , TPG(YcbCr,4:2:2,sequence,interlaced output)->CVO I get proper color pattern output.
I then tried , TPG(YcbCr,4:2:2,progressive,parallel)->ITL->CPS->CVO , I get CVO underflow and the output image is not proper.
Can anyone tell me the correct usage of Interlacer IP ? I read in the VIP userguide that it works with odd heights of the image?If it is so how can i go about getting a valid output? Any leads would be greatly appreciated.
Thankyou and Regards,
Vidya
