10 years agoProblem with VIP suite on Cyclone V device
Hello, I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader ou...
10 years agoHi Ted,
I tried with Frame buffer in front of CVO. I get the output as in TPG_VFB_CVO.bmp with rolling video. The test pattern that I see is not the same as given in the VIP user guide Test pattern generator output. Also I have attached signal tap signals capture vip_osd.jpg. You can see that the CVO underflows during 17th line. Can this mean something ? I'm clueless here. Thanks & Regards, Vidya
