10 years agoProblem with VIP suite on Cyclone V device
Hello, I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader ou...
10 years agoHi Ted,
Thanks a lot for your suggestions. I tried with frame repetition on and increased the Frame buffer Avalon MM write and read fifo sizes. Now I get a proper test pattern at the output with no underflow of CVO but still it seems to be somewhat distorted. I have attached the output image. Could it be the problem with any other CVO or Frame buffer setting? Regards, Vidya
