10 years agoProblem with VIP suite on Cyclone V device
Hello, I am trying to work with VIP suite. My main objective is to read YCbCr 4:2:2 progressive 720x576 image from HPS DDR3 into the VIP suite using Frame reader , interlace the frame reader ou...
10 years agoHi Ted,
You are right. I transcribed the packet data wrongly by missing 00 which is valid for two clock cycles. But then I can not figure why the CVO is underflowing. I'm attaching the output with CVO fifo depth 720, start size 719 namely TPG_CVO_output1.bmp and the output with CVO fifo depth 13824 , start size 13823 namely TPG_CVO_output2.bmp Can you help me in figuring out where the problem could be? Thanks & Regards, Vidya
