CaptainPrice15's avatar
CaptainPrice15
1 year ago
Pin allocation for PCIe HIP gen 2 x1 with Avalon-MM Interface
I wish to use the Intel HIP for cyclone 10GX with a F780 package. I wish to use only 1 lane of PCIe 2.0 with Avalon-MM as interface. The quartus software is allowing me to place the tx pin pair only on the pins W28 and W27, the rx pin pair only on pins v26 and v25.
The worse part being that it is allowing me to place the 'perst' pin only on the pin AB11 which is impossible for me. I am already uisng this pin, and the bank 2A (which contains the pin AB11) with an IO Voltage of 1.35V while the 'perst' pin needs 1.8V.
Is there any wayout from this? I do not wish to redesign my custom board and change all the connections from bank 2A only for the 'perst' pin to get the pin AB11.
Any quick help is appreciated.
Thanks in advance!
  • Wincent_Altera's avatar
    Wincent_Altera
    Thanks for contacting Altera. I'm assigned to support request.
    I'll investigate and get back to you soon. Thanks for your patience.
    Wincent_Altera
    Wincent_Altera
    Hi @CaptainPrice15 ,
    >> Yes , the pin perst need 1.8V as compulsory
    May I know which device OPN of Cyclone 10 GX that you are using ?
    For particular device we would have a different pin out mapping where you can refer to
    https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html#tab-blade-1-3
    With that you can try to find any alternative pin which is un-use and could be compatible, but please ensure the IO standard is same as perst pin.
    Wincent
    Wincent_Altera
    Is there anything else you think I could help you ?
    Wincent
    Wincent_Altera
    Hope my previous reply clear the doubt of the pin implementation.
    I might be miss-out something, please let me know you think I could better clarified/help out.
    Wincent_Altera​
