Pin allocation for PCIe HIP gen 2 x1 with Avalon-MM Interface
Hi @CaptainPrice15 ,
I am already uisng this pin, and the bank 2A (which contains the pin AB11) with an IO Voltage of 1.35V while the 'perst' pin needs 1.8V.
>> Yes , the pin perst need 1.8V as compulsory
May I know which device OPN of Cyclone 10 GX that you are using ?
For particular device we would have a different pin out mapping where you can refer to
https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html#tab-blade-1-3
With that you can try to find any alternative pin which is un-use and could be compatible, but please ensure the IO standard is same as perst pin.
Wincent
- CaptainPrice151 year ago
Hello @Wincent_Altera ,
Thanks a lot for your reply. I am using the 10CX150YF780E5G. I tried placing the perst pin on other banks where 1.8V is provided, but I don't know why, the fitter would like to place the perst only on AB11 (please see screenshot.)
The assigned pin for perst (Pin E22) as seen in the screenshot is in bank 2L which I have supplied with 1.8V.
- Wincent_Altera1 year ago
Do you use this pin for configuration purpose ?
IF not, you have the option to select 1.2V, 1.5V, or 1.8V compatible I/O standard.
Detail please refer below
https://www.intel.com/content/www/us/en/docs/programmable/683417/current/optional-dual-purpose-configuration-pins.htmlRegards,
Wincent_Altera
Thanks a lot for your reply. No, I do not need the pin for configuration purpose. I have read the document you provided in your reply and do understand that I have the option to select 1.2V, 1.5V, or 1.8V compatible I/O standard. That being said, as seen in the screenshot I attached in one of my previous replies, the Quartus software doesn't allow me to allocate the nPERST pin to any other IO. It is reluctant that I assign the pin AB11 to it; which is unfortunately not possible for me.
