12 years ago
PCIe transceiver offset cancelation
Device - Stratix IV
Using PCIe x4 Gen2.
For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using the pll_locked as the reset generator. Like this,
altgx_reconfig altgx_0_reconfig (
.offset_cancellation_reset(~pll_locked), // pll locked
.reconfig_clk (pll_clk_50), // clock from PLL
.reconfig_fromgxb (reconfig_0_fromgxb),
.busy (busy),
.reconfig_togxb (reconfig_togxb)
This works perfectly. But I need to free up this PLL and use for another purpose and I am thinking of using a clock coming directly from the pin. And I am not quite sure what to do with the reset, I tried to ground the reset altogether which made the PCIe not to come up at all. Now I am thinking the pcie reset could be connected to the altgx_reconfig. Like this,
altgx_reconfig altgx_0_reconfig ( .offset_cancellation_reset (~pcie_rstn), // PCIe reset
.reconfig_clk (clkin_50), // clock coming from a x'tal
.busy (busy),
But that did not work either. PCI express is not responding. Any ideas what I could do?
    --- Quote Start ---
    Its quite possible that is the case, and it would probably be acceptable. Its worth poking around in your hardware to get a sense of what is going on at the system level, and then write your testbenches to match that and several other power-up sequences to see if your design behaves correctly.
    Cheers,
    Dave
    --- Quote End ---
    Ok so, I got some more data. Seems like after cold boot of the host PC, PCIe reset is asserted for almost ~500ms (see the pic, signal captured). C1(yellow) is the pcie reset and c2 (pink) is the Vcc.
    https://www.alteraforum.com/forum/attachment.php?attachmentid=7064
    But when I restart the PC, the reset is asserted only for a ~5ms, I am not sure if there is another reset coming after this, but I doubt it. See the pic below
    https://www.alteraforum.com/forum/attachment.php?attachmentid=7065
    So I think my signaltap in the earlier post shows that the pci reset occured long before the FPGA configuration finished and thats the reason I am not seeing reset being asserted in the waveform. That also means that I am not really getting a proper reset to my FPGA logic (except for the PCIe hard IP block) since all my logic resets are connected to the pcie reset (except for the altgx_reconfig block for which I generated a reset internally).
    --- Quote Start ---
    --- Quote End ---
    Great! Thanks.
    These are reasonable waveforms.
    Keep in mind that the FPGA offset cancellation routine only ever runs when the FPGA is first configured, eg., when its powered or reprogrammed via JTAG or another configuration source. After that point, the ALTGX_RECONFIG busy signal will not assert right after reconfig_reset or offset_cancellation_reset deasserts to indicate offset cancellation is running.
    Note: that if you reconfigured your FPGA using JTAG, pressed the reset button, and then took the SignalTap II traces, you would see the ALTGX_RECONFIG busy signal asserted while offset cancellation is running, and PCIe reset would be deasserted (if you missed the 5ms low time of the signal).
    --- Quote Start ---
    --- Quote End ---
    Its possible. But if those plots were also showing offset cancellation running (busy high), the reset signal should be low (if it was a power-on SignalTap II trace).
    --- Quote Start ---
    --- Quote End ---
    5ms is more than long enough for a reset.
    The PCIe reset should be passed through reset synchronizers that asynchronously assert and synchronously deassert for each of the clock domains in your design that PCIe reset is supposed to reset. Assuming all of these clocks are in the MHz range, 5ms is thousands of clocks.
    Is the PCIe interface working in either or both of these reset sequences/conditions?
    If the power-on-reset is not working, then probe CONF_DONE to see when your FPGA is configured relative to PCIe reset deasserting.
    Cheers,
    Dave
    --- Quote Start ---
    Great! Thanks.
    --- Quote End ---
    Its not loaded through JTAG, but is configured by the CPLD on powerup, I flashed the binary. In my case, I dont have any other reset other than PCIe reset (No reset button/other POR). So on PERST# assertion, CPLD programs the FPGA and since the reprogramming will take more than 5ms (FPP), by the time config is done, the PERST# reset would already have been deasserted in the case of a PC Reset.
    --- Quote Start ---
    --- Quote End ---
    Yes, it was a Power-on signaltap. Offset cancellation went busy after my internally generated reset was asserted, but I never saw the PCIe reset being asserted in my signaltap.
    --- Quote Start ---
    --- Quote End ---
    Yes, but since I am programming the FPGA on this reset, once config is done, reset would have already deaaserted.
    --- Quote Start ---
    --- Quote End ---
    Yes, PCIe interface seems to be working fine. Enumeration is done and device is transferring data. The only thing I am unable to do is to cause a re-enumeration without restarting the PC. (For eg. if I reprogram the FPGA via JTAG, and try to access the PCIe interface, it would not be recognized, since the enumeration is happening only during powerup/reboot). Any idea, if there is a way I can achieve that? Hotplug?/warm reset?
    --- Quote Start ---
    --- Quote End ---
    I was trying to do that, but unfortunately I dont have any vias on the board to probe on conf_done. All I could get my probe on was the nConfig signal (config start), which as you would expect is happening at the reset edge.
    --- Quote Start ---
    --- Quote End ---
    This is not the correct solution.
    When the CPLD first powers on, it should program the FPGA. There is no need to program the FPGA when PERST# asserts.
    --- Quote Start ---
    --- Quote End ---
    Yeah, you can use hot-plug under Linux. I'm not sure about Windows.
    --- Quote Start ---
    --- Quote End ---
    If you are using a CPLD to program the FPGA, then you should have a pretty good idea as to how long programming will take. So how long is that?
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    You are right, I had it that way before, but faced some issues with binary update at site when the host PC just does a warm boot after a system update. So now I just put it to update every time there is a PCIe reset.
    --- Quote Start ---
    --- Quote End ---
    I would like to understand how to do that(in linux), Can you please point me to any docs? or give some more info, Thanks! We have PC platform, but I may get some idea.
    --- Quote Start ---
    --- Quote End ---
    I had to check it.. Its taking about 600ms, and since there is an internal delay or something on a powerup, it takes more than a sec (1100ms) after powerup before the FPGA is programmed and ready.
    So definitely I am missing the pcie reset (in both cases, PC Cold Boot/Warm boot) I attached the waveforms as well. So, I am going to generate a reset after the PCIe reset and the reconfiguration.
    PC after Cold Boot (there is a mistake in signal name, pink is fpga config done)
    https://www.alteraforum.com/forum/attachment.php?attachmentid=7070
    PC After Warm boot
    https://www.alteraforum.com/forum/attachment.php?attachmentid=7071
    PC After Warm Boot - Zoomed to show the PERST# since its only a 5ms.
    https://www.alteraforum.com/forum/attachment.php?attachmentid=7072
    --- Quote Start ---
    --- Quote End ---
    This "fix" is causing you other problems, so really you need to fix this problem first.
    --- Quote Start ---
    --- Quote End ---
    Send me an email to my forum name and I'll forward an email discussion that I had on this topic.
    --- Quote Start ---
    --- Quote End ---
    This is not good. You need to determine all of your power on timing delay sources, eg., look at your on-board power-supplies, their ramp times, etc. Your board may be violating the power-on-requirements of the FPGA, i.e., hiding even more issues.
    --- Quote Start ---
    --- Quote End ---
    Generating another reset is not going to help. What you are not looking at in these traces is the PCIe bus activity. Your PCIe end-point will miss the traffic on the bus that configures it. If its working in this motherboard, then its just luck. The next motherboard you plug it into, it may not work.
    The "solution" is to;
    1) Configure the FPGA at power-on "as fast as possible", ideally within 100ms, but if you cannot achieve that, then faster than the deassertion of PCIe reset.
    2) Do not reconfigure when PCIe reset asserts. There is no reason to. The FPGA just needs to treat the PCIe reset as a reset source. You don't have to reset all logic within the FPGA if you do not want to, eg., you can have a "last reset reason" register that sets a power-on bit at power on, and a PCIe reset bit when PCIe reset occurs (of course if your FPGA configures faster than PCIe reset deasserts, then you'll only ever see the PCIe reset bit set).
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    Thanks. I am going to look at why there is that significant delay during cold boot than on a warm boot.
    --- Quote Start ---
    --- Quote End ---
    I checked the CPLD, we are using a 50MHz clock and Flash access time(from where the data is fetched by CPLD) is about 70ns, and due to that each byte is taking about 100ns to be sent to the FPGA during configuration. The configuration data for our device is about 6MBytes and that explains why CPLD takes about 600ms to finish the reconfiguration. Yes, I still need to check why there is some extra time taken on a cold boot, but I may not still be able reconfigure the FPGA within 100ms, or not even 500ms.
    --- Quote Start ---
    --- Quote End ---
    Yeah, I agree. I am going to make the change, Thanks!
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    --- Quote Start ---
    I checked the CPLD, we are using a 50MHz clock and Flash access time (from where the data is fetched by CPLD) is about 70ns, and due to that each byte is taking about 100ns to be sent to the FPGA during configuration. The configuration data for our device is about 6MBytes and that explains why CPLD takes about 600ms to finish the reconfiguration. Yes, I still need to check why there is some extra time taken on a cold boot, but I may not still be able reconfigure the FPGA within 100ms, or not even 500ms.
    --- Quote End ---
    Ok, so this is a design "feature" then. This complicates the use of this board, since it will work in some motherboards, but not others.
    The board designer's responsibility is to perform a timing analysis (like the one in the doc I linked to) and as shown in this doc:
    http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf
    For example, see the timing diagram on p30 where 16-bit flash reads are used to program an FPGA in FPP mode. The flash read access timing is what limits the design. Using page-mode flash helps. Review your design. Perhaps the board has page mode flash, and you're not using that feature. That might allow you to speed things up slightly.
    Cheers,
    Dave
    I sent an email to you.
    --- Quote Start ---
    --- Quote End ---
    This board is not sold separately, but is part of a larger system, so it is integrated with a known (tested) motherboard in all situations.
    And since we are using hard IP, (which would be up and running at powerup), even though configuration is delayed, the PC is able to talk to the hard IP and get it enumerated once PCIe reset is deasserted (even though I am wondering how it is working with a late algx_reconfig_reset). EDIT : I think my statement not be true. Even though its a hardIP implemetation, FPGA reconfiguration has to be finished for the PCIe hardIP to respond to config read requests from the motherboard?
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    Yes, I have M29EW flash device (micron), and it supports the page buffer read mode (with 25ns read access time), but seems like the PFL doesnt have that option. I only have a spansion page mode access (in advanced read mode) listed, which gave me a slight improvement in read latency, but it still takes more than 500ms to configure the FPGA.
    I found out why there is an added delay during powerup, it was because the configuration was only starting once the FPGA reset was deasseted (since the PFL was configured to reprogram on pcie reset), Once I removed it, the fpga programming takes about ~600ms, still outside the reset assertion. Thanks for sharing the document.
    --- Quote Start ---
    --- Quote End ---
    I've responded to it.
    --- Quote Start ---
    --- Quote End ---
    Great. Then your job now is to document these timing requirements, and the requirements for the motherboard. If you do not do this now, some poor soul (perhaps yourself) will have to figure out why things are not working with "the new motherboards" some time in the future.
    --- Quote Start ---
    --- Quote End ---
    FPGA reconfiguration and link training has to be complete - the details are in the timing figure I referred you to earlier.
    --- Quote Start ---
    --- Quote End ---
    Ignore what PFL gives you. Do the math. What is the fastest you should be able to configure the FPGA? If the best you can do is close to this number, then there is no reason to change the implementation.
    However, even if you find you can make it faster, you do not need to (since your motherboard is ok with the current timing). Just document that the design could be improved, and show how. Later if this product needs to be revised, these types of changes can be made.
    Cheers,
    Dave
