13 years agoPCIe transceiver offset cancelation
Device - Stratix IV Using PCIe x4 Gen2. For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using th...
13 years ago --- Quote Start --- When the CPLD first powers on, it should program the FPGA. There is no need to program the FPGA when PERST# asserts. --- Quote End --- You are right, I had it that way before, but faced some issues with binary update at site when the host PC just does a warm boot after a system update. So now I just put it to update every time there is a PCIe reset. --- Quote Start --- Yeah, you can use hot-plug under Linux. I'm not sure about Windows. --- Quote End --- I would like to understand how to do that(in linux), Can you please point me to any docs? or give some more info, Thanks! We have PC platform, but I may get some idea. --- Quote Start --- If you are using a CPLD to program the FPGA, then you should have a pretty good idea as to how long programming will take. So how long is that? --- Quote End --- I had to check it.. Its taking about 600ms, and since there is an internal delay or something on a powerup, it takes more than a sec (1100ms) after powerup before the FPGA is programmed and ready. So definitely I am missing the pcie reset (in both cases, PC Cold Boot/Warm boot) I attached the waveforms as well. So, I am going to generate a reset after the PCIe reset and the reconfiguration. PC after Cold Boot (there is a mistake in signal name, pink is fpga config done) https://www.alteraforum.com/forum/attachment.php?attachmentid=7070 PC After Warm boot https://www.alteraforum.com/forum/attachment.php?attachmentid=7071 PC After Warm Boot - Zoomed to show the PERST# since its only a 5ms. https://www.alteraforum.com/forum/attachment.php?attachmentid=7072
