13 years agoPCIe transceiver offset cancelation
Device - Stratix IV Using PCIe x4 Gen2. For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using th...
13 years ago --- Quote Start --- on PERST# assertion, CPLD programs the FPGA --- Quote End --- This is not the correct solution. When the CPLD first powers on, it should program the FPGA. There is no need to program the FPGA when PERST# asserts. --- Quote Start --- The only thing I am unable to do is to cause a re-enumeration without restarting the PC. (For eg. if I reprogram the FPGA via JTAG, and try to access the PCIe interface, it would not be recognized, since the enumeration is happening only during powerup/reboot). Any idea, if there is a way I can achieve that? Hotplug?/warm reset? --- Quote End --- Yeah, you can use hot-plug under Linux. I'm not sure about Windows. --- Quote Start --- I was trying to do that, but unfortunately I dont have any vias on the board to probe on conf_done. All I could get my probe on was the nConfig signal (config start), which as you would expect is happening at the reset edge. --- Quote End --- If you are using a CPLD to program the FPGA, then you should have a pretty good idea as to how long programming will take. So how long is that? Cheers, Dave
