Abhi_Krishnan_R's avatar
Abhi_Krishnan_R
2 months ago
PCIe Hard IP - Can 'valid' De-assert Between SOP and EOP During DMA Read Completion?
Product / IP: Intel PCIe Hard IP (Avalon-ST Interface
Device Family: Cyclon 10 GX
Reference Manual:
https://docs.altera.com/r/docs/683647/18.0/arria-10-and-cyclone-10-gx-avalon-streaming-interface-for-pci-express-user-guide/datasheet
I am an FPGA Design Engineer currently working on verifying the application layer logic interfacing with Intel's PCIe Hard IP over the Avalon Streaming (Avalon-ST) interface.
As part of the verification effort, I have developed an Avalon-ST Bus Functional Model (BFM) that mimics the RX-side behavior of the PCIe Hard IP — specifically, how it presents TLP data (DMA Read Completions) to the downstream application logic.
During simulation, my BFM generates scenarios where the 'valid' signal is de-asserted between 'startofpacket (SOP)' and 'endofpacket (EOP)' — i.e., mid-packet gaps or "bubbles" are introduced within a single TLP transfer. When this occurs, the application layer logic does not handle it correctly, causing functional failures.
Before proceeding with fixing the application logic to handle this case, I need to confirm from Intel whether this behavior is actually possible on the real PCIe Hard IP hardware
Question 1: On the RX Avalon-ST interface, when the PCIe Hard IP is acting as the SOURCE (driving TLP completion data toward user application logic), is it possible for the 'valid' signal to be de-asserted between SOP and EOP within the same TLP packet?
Question 2: If yes, under what conditions can this occur?
Question 3: Does the Intel PCIe Hard IP Reference Manual explicitly document this behavior anywhere? If so, could you point to the relevant section?
