PCIe Hard IP - Can 'valid' De-assert Between SOP and EOP During DMA Read Completion?
Hi Abhi_Krishnan_R ,
For the behaviour of rx_st_eop/sop. I think you can refer below document as a reference
https://docs.altera.com/r/docs/683059/25.1.1/p-tile-avalon-streaming-fpga-ip-for-pci-express-user-guide/avalon-st-rx-interface-rx_st_ready-behavior
For C10 device, you may check under AVST interface section
https://docs.altera.com/r/docs/683647/18.0/arria-10-and-cyclone-10-gx-avalon-streaming-interface-for-pci-express-user-guide/interfaces-and-signal-descriptions
Wincent_Altera
Thanks for your response. I have gone through the references you provided.
In the first link, the explanation mainly about application-side throttling when PCIe acts as the source. However, my concern is whether the PCIe IP itself can throttle the bus while transmitting data(Source), particularly during DMA operations.
I also reviewed the interface section in the second reference. It similarly mentions only application-level throttling, and I could not find any details indicating whether the PCIe core independently throttles the bus, or under what conditions it might do so.
Could you please clarify if the PCIe IP has any mechanism to throttle the bus during DMA transfers(when PCIe act as a source), or if throttling is entirely controlled by the application logic?
- Wincent_Altera5 months ago
In normal operation of PCIe IP design example provided by Altera , the throttle/bubble is not a normal operation. Regarding throttling based on my experience and understanding on RX (PCIe → user), throttling is governed by your application through rx_st_ready. The PCIe HIP does not arbitrarily throttle mid‑packet while ready remains asserted; it responds to backpressure and streams at the interface clock rate otherwise.
If you want to stress the design, I would suggest to de‑assert rx_st_ready for arbitrary spans within a TLP and verify proper resume to EOP. To be honest I do not have any exact answer as this is something customize and I never try before, Hope my suggestion able to help you to move a step forward.
Wincent - Wincent_Altera5 months ago
Is there anything else I can better assist you ?
Wincent_Altera- Abhi_Krishnan_R5 months ago
Hi Wincent_Altera ,
Sorry for the delayed response.
Regarding your previous comment, I understand that this might be a slightly grey area. It would be really helpful if you could point me to any available documentation or references that clarify whether the PCIe Hard IP guarantees continuous valid assertion from SOP to EOP for a given TLP.
I’ve observed this behavior in my simulations, and I just want to make sure I’m aligning correctly with the intended behavior of the Hard IP. Without confirmation on this, I’m unsure whether to treat this as a BFM limitation or if the DUT should be updated to handle such scenarios.
Any guidance or pointers would be greatly appreciated, as this will help me proceed in the right direction.
Abhi Krishnan R
Under page 59 of your provided guide (in the forum description)
Got mentioning the way to handle the delay of SOP and EOP by given TLPThe maximum latency will be 1/2 clock. Hope this able to help you to move forward.
Let me know if I understand this incorrect.
Wincent
