14 years ago
HD SDI and Clocked Video Input issues
I'm having trouble integrating an HD SDI transceiver into my existing Stratix IV GX video design. I've ended up stripping it down to a single video path and integrating in the AN600 design to debug the issues, but I'm still unable to get valid video through the system.
My SOPC system is as follows:
CVI -> CRS -> CSC -> Deint (Bob, no buffering) -> CPR (parallel -> serial) -> Clipper (no clipping) -> Scaler (1920x1080 to 640x480) -> VFB (triple buffer) -> CPR (serial -> parallel) -> CVO
The conversion from parallel to serial and vise versa is an artifact of the pre-existing design. The clipper is currently software configurable but not clipping any of the frame.
I have the AN600 Rx-only transceiver driving the CVI. I have the Tx-only transceiver with the test pattern generator hard coded for HD SDI (tx_std = "01"). Using SignalSpy, I can see the data port on the Tx and the Rx sides and everything looks good. I'm seeing valid Vsync, Hsync and Field flags and the Rx_status is 0x01D indicating it has achieved PLL, alignment, TRS and Frame lock.
Looking at the CVI using SignalSpy, I'm seeing the overflow flag set constantly. I'm seeing valid Vsync, Hsync and Field flags. The active_line_count_f0 is 0x0C48 and active_line_count_f1 is 0x0439?? The total_line_count_f0 is 0x0465 and total_line_count_f1 is 0x0467. total_sample_count is 0x1131?? The CVI internal locked flag periodically deasserts for a full video line period.
When I configured the Clocked Video Input module, I used the SDI 1080i60 preset.
Does anyone have any input on what could be wrong here? Any advice on what to look at?
