deinterlace IP
deinterlace II ip ,when i select 8bit or 12bit of color sample, my program is working properly, but when i select 10bit, is abnormal. The input is the same
- Deshi_Intel
I am not sure what colour format that you use. Have you try with different color format input ?
Are you using latest Quartus version else you can try upgrade to latest Quartus version to see if the issue still persist ?
Also you can try out different deinterlacing algorithm to see if it make a difference
dlim
- arlen
Hi,I use the colour format of RGB??the video source is RGB colour format? so i didn‘t try other format input.And Quartus version i use is 18.2, my colleague used was 18.1, we use same deinterlacing algorithm, but his project work properly.Could you have example project about using deinterlace II ip ? - Deshi_Intel
Unfortunately we don't have the example design.
Intel FPGA doesn't offer v18.2. I presume you are referring to v18.1.2 ?
To rule out potential old Quartus version issue,
- pls try to upgrade to latest Quartus version if possible.
- Since it's working on your colleague PC, you can install v18.1 on your PC to see if it's v18.1.2 version issue but I doubt so
Another thing to check is to ensure your FPGA design is timing clean to avoid design functionality failure
dlim
- arlen
hi,
现在发现主要问题还是avalon-mm接口,发现deinterlace ip 出来的某次读突发会导致avalon-st接口的ready拉低一直不变,st接口按照协议打包正确,mm接口也是按照官方手册的时序进行操作的,但是有一点就是我同事的mm接口没有突发长度为1的时候,但是我这边频繁出现,官方对这个IP没有任何时序上的介绍,所以也不知道问题现在在哪
- Deshi_Intel
HI,
The timing diagram spec of all Video IP is shared and explained in chapter 2 of the VIP user guide doc. Feel free to check it out.
dlim
- arlen
发现当deinterlace ip参数设置中的Avalon-MM接口位宽设置为256bit时,屏幕就不显示,Avalon-ST接口的ready就拉起不来;而选择接口位宽为512bit时,但由于我的emif是320bit位宽,所以我只截取MM接口的低256bit进行读写DDR。最终显示图像的现象是文字会抖动,应该是少了一半有效数据的关系。
但为什么ip 选择256不行,而选择512可以?
- arlen
选择256和512以及128bit位宽有什么区别?
- Deshi_Intel
The bus bit width should only affect the operating frequency to maintain the same video bandwidth
- For instance, when the bus bit width x2, the operating frequency should be divided x 2
- when the bus bit width x4, the operating frequency should be divided x 4
If larger bus bit width works, I suspect your design could be facing timing closure issue where the data transfer can only happen safely with lower operating frequency
dlim
- arlen
但是为什么512bit位宽是可以的?如果按照您的说法,更改位宽需要更大的频率,256bit不行,那么512bit也应该不行
- Deshi_Intel
I am not sure I am following your explanation here.
- Sorry, this is English forum so I am having tough time to understand chinese translation here
When bus width goes higher, the expected operating frequency should goes lower.
- Assuming bus width = 128, required operating frequency = 1x
- when bus width = 256, required operating frequency = 1x divide by 2
- when bus width = 256, required operating frequency = 1x divide by 4
dlim
- Deshi_Intel
Sorry, typo in my earlier post
- Assuming bus width = 128, required operating frequency = xxx MHz
- when bus width = 256, required operating frequency = xxx MHz divided by 2
- when bus width = 512, required operating frequency = xxx MHz divided by 4
