arlen
5 years agodeinterlace IP
deinterlace II ip ,when i select 8bit or 12bit of color sample, my program is working properly, but when i select 10bit, is abnormal. The input is the same
arlen
5 years agoHi,
I use the colour format of RGB??the video source is RGB colour format? so i didn‘t try other format input.
And Quartus version i use is 18.2, my colleague used was 18.1, we use same deinterlacing algorithm, but his project work properly.
Could you have example project about using deinterlace II ip ?
