arlen
5 years agodeinterlace IP
deinterlace II ip ,when i select 8bit or 12bit of color sample, my program is working properly, but when i select 10bit, is abnormal. The input is the same
Deshi_Intel
5 years agoHi,
The bus bit width should only affect the operating frequency to maintain the same video bandwidth
- For instance, when the bus bit width x2, the operating frequency should be divided x 2
- when the bus bit width x4, the operating frequency should be divided x 4
If larger bus bit width works, I suspect your design could be facing timing closure issue where the data transfer can only happen safely with lower operating frequency
dlim
- arlen5 years ago
但是为什么512bit位宽是可以的?如果按照您的说法,更改位宽需要更大的频率,256bit不行,那么512bit也应该不行
