arlen
5 years agodeinterlace IP
deinterlace II ip ,when i select 8bit or 12bit of color sample, my program is working properly, but when i select 10bit, is abnormal. The input is the same
Deshi_Intel
5 years agoHi,
I am not sure what colour format that you use. Have you try with different color format input ?
Are you using latest Quartus version else you can try upgrade to latest Quartus version to see if the issue still persist ?
Also you can try out different deinterlacing algorithm to see if it make a difference
dlim
