arlenNew Contributor5 years agodeinterlace IP deinterlace II ip ,when i select 8bit or 12bit of color sample, my program is working properly, but when i select 10bit, is abnormal. The input is the same Show More
Recent DiscussionsAgilex 3 MIPI D-PHY RX: Does it support P/N polarity inversion?GTS SDI II IP System PLL Frequency Issue in Quartus Prime Pro Edition 26.1.1Agilex-5 supported TransceiversSolvedA5E : high transceiver power consumption?quartus ram gen full HDL
