drbarryh's avatar
drbarryh
9 months ago
Confusion for TX Clock direction for Triple Speed 1G Ethernet IP?
Hello ALTRA IP experts,
Can anybody please explain to me why, when i set the Triple Speed Ethernet IP up for RGMII mode, the tx clock for the MAC is set as an input?
eth_tse_0_pcs_mac_tx_clock_clk   : in  std_logic                     := 'X';             -- clk
I was expecting this signal to be an output for the Transmit MAC section to to the PHY TX block ?
Here are all of the signal connections i get when i setup in RMII mode for the Triple Speed 10/100/1000 Ethernet IP core  (its easier to see directions and sizes using the VHDL instance template) :
eth_tse_0_mac_status_set_10      : in  std_logic                     := 'X';             -- set_10
eth_tse_0_mac_status_set_1000    : in  std_logic                     := 'X';             -- set_1000
eth_tse_0_mac_status_eth_mode    : out std_logic;                                        -- eth_mode
eth_tse_0_mac_status_ena_10      : out std_logic;                                        -- ena_10
eth_tse_0_mac_rgmii_rgmii_in     : in  std_logic_vector(3 downto 0)  := (others => 'X'); -- rgmii_in
eth_tse_0_mac_rgmii_rgmii_out    : out std_logic_vector(3 downto 0);                     -- rgmii_out
eth_tse_0_mac_rgmii_rx_control   : in  std_logic                     := 'X';             -- rx_control
eth_tse_0_mac_rgmii_tx_control   : out std_logic;                                        -- tx_control
eth_tse_0_receive_data           : out std_logic_vector(31 downto 0);                    -- data
eth_tse_0_receive_endofpacket    : out std_logic;                                        -- endofpacket
eth_tse_0_receive_error          : out std_logic_vector(5 downto 0);                     -- error
eth_tse_0_receive_empty          : out std_logic_vector(1 downto 0);                     -- empty
eth_tse_0_receive_ready          : in  std_logic                     := 'X';             -- ready
eth_tse_0_receive_startofpacket  : out std_logic;                                        -- startofpacket
eth_tse_0_receive_valid          : out std_logic;                                        -- valid
eth_tse_0_transmit_data          : in  std_logic_vector(31 downto 0) := (others => 'X'); -- data
eth_tse_0_transmit_endofpacket   : in  std_logic                     := 'X';             -- endofpacket
eth_tse_0_transmit_error         : in  std_logic                     := 'X';             -- error
eth_tse_0_transmit_empty         : in  std_logic_vector(1 downto 0)  := (others => 'X'); -- empty
eth_tse_0_transmit_ready         : out std_logic;                                        -- ready
eth_tse_0_transmit_startofpacket : in  std_logic                     := 'X';             -- startofpacket
eth_tse_0_transmit_valid         : in  std_logic                     := 'X';             -- valid
eth_tse_0_mac_mdio_mdc           : out std_logic;                                        -- mdc
eth_tse_0_mac_mdio_mdio_in       : in  std_logic                     := 'X';             -- mdio_in
eth_tse_0_mac_mdio_mdio_out      : out std_logic;                                        -- mdio_out
eth_tse_0_mac_mdio_mdio_oen      : out std_logic;                                        -- mdio_oen
eth_tse_0_mac_misc_magic_wakeup  : out std_logic;                                        -- magic_wakeup
eth_tse_0_mac_misc_magic_sleep_n : in  std_logic                     := 'X';             -- magic_sleep_n
eth_tse_0_mac_misc_ff_tx_crc_fwd : in  std_logic                     := 'X';             -- ff_tx_crc_fwd
eth_tse_0_mac_misc_ff_tx_septy   : out std_logic;                                        -- ff_tx_septy
eth_tse_0_mac_misc_tx_ff_uflow   : out std_logic;                                        -- tx_ff_uflow
eth_tse_0_mac_misc_ff_tx_a_full  : out std_logic;                                        -- ff_tx_a_full
eth_tse_0_mac_misc_ff_tx_a_empty : out std_logic;                                        -- ff_tx_a_empty
eth_tse_0_mac_misc_rx_err_stat   : out std_logic_vector(17 downto 0);                    -- rx_err_stat
eth_tse_0_mac_misc_rx_frm_type   : out std_logic_vector(3 downto 0);                     -- rx_frm_type
eth_tse_0_mac_misc_ff_rx_dsav    : out std_logic;                                        -- ff_rx_dsav
eth_tse_0_mac_misc_ff_rx_a_full  : out std_logic;                                        -- ff_rx_a_full
eth_tse_0_mac_misc_ff_rx_a_empty : out std_logic;                                        -- ff_rx_a_empty
clk_out_5_clk                    : out std_logic;                                        -- clk
eth_tse_0_pcs_mac_rx_clock_clk   : in  std_logic                     := 'X';             -- clk
eth_tse_0_mac_clkena_rx_clkena   : in  std_logic                     := 'X';             -- rx_clkena
eth_tse_0_mac_clkena_tx_clkena   : in  std_logic                     := 'X'              -- tx_clkena
These all make sense to me EXCEPT for the eth_tse_0_pcs_mac_tx_clock_clk  signal which i thought would be an OUPUT and NOT and INPUT !
Thanks for your help,
Barry
  • In RGMII, the MAC does not generate its own transmit clock.
    Instead, the PHY is responsible for supplying the 125/25/2.5 MHz TX clock back to the MAC.
    So, MAC sends TX data (txd and tx_ctl) to the PHY. The PHY returns a clock  that is aligned with the transmitted data. The MAC uses this returned clock to output the next cycle of data. Hence, This is correct for RGMII as an input signal.
    Hope this helps.
  • Greetings Pavee, Thanks for your reply.
    But that is incorrect for my application. Looking for example at an ALTERA MAX10 10M50-C development kit, which has a pair of Triple Speed Ethernet connections, and using a MARVELL 88E1111 PHY, on page 53 of the MARVELL Data sheet it is clearly shown in RGMII mode that the Tx clock is an INPUT to the MARVELL PHY device (TXC, going to GTX_CLK in the PHY), and an OUTPUT from the MAC (which is inside the MAX10 FPGA in this case) and so the so the Tx clock is coming from the ALTERA Triple Speed IP core instantiated and configured in MAC only mode..
    I am not sure if this is the usual case but it certainly is in this case.
    Dr Barry H
    • paveetirrasrie_Altera's avatar
      Hello Barry,
      May I know if you've further query on this matter?
      Pavee
  • FvM's avatar
    FvM
    Hi Barry,
    according to TSE IP User Guide, interface between FPGA and RGMII PHY looks like this
    means 5/25/125 MHz clock has to be generated in your design. That's valid for all PHY with RGMII interface, not specifically Marvell 88E1111.
    Frank
  • FvM's avatar
    FvM
    Hi Barry,
    according to TSE IP User Guide, tx_clk has to be send to RGMII PHY and TSE IP by your design. A programmable clock divider is required to support 10 and 100 MBit mode.
    Frank
