drbarryh
Contributor
9 months agoConfusion for TX Clock direction for Triple Speed 1G Ethernet IP?
Hello ALTRA IP experts, Can anybody please explain to me why, when i set the Triple Speed Ethernet IP up for RGMII mode, the tx clock for the MAC is set as an input? eth_tse_0_pcs_mac_tx_clock_clk ...
paveetirrasrie_Altera
9 months agoIn RGMII, the MAC does not generate its own transmit clock.
Instead, the PHY is responsible for supplying the 125/25/2.5 MHz TX clock back to the MAC.
So, MAC sends TX data (txd and tx_ctl) to the PHY. The PHY returns a clock that is aligned with the transmitted data. The MAC uses this returned clock to output the next cycle of data. Hence, This is correct for RGMII as an input signal.
Hope this helps.
