sadad's avatar
sadad
7 years ago
Avalon Interconnect Dynamic Bus Sizing and Bursts
Hello!
My Avalon-MM master has 32bit data width and is bursting capable.
Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable.
Will a 32bit read or write access to the slave cause the automatically generated Avalon adapter to translate the 1x32bit access to a single burst of 4 x 8bit?
Or will there be 4 non bursting transfers of 8bit?
Thanks in Advance!
  • KennyT_altera's avatar
    KennyT_altera
    I forgot to mention I did not pull in the ram module in the simulation, you will have to add it to the *.do file before run -a. Here is the screenshot, the current test is the readata is 16bits while the write data at the master is 32bits.
  • sadad's avatar
    sadad
    Would you please mark the important regions in your screenshot? I can not see any signal regarding the burstcount. I can only see that burstcount is in an invalid state 'X'.
    I checked your qsys design => the onchip ram has 32bit avalon mm bus => so there wont be any translation.
  • sadad's avatar
    sadad
    Is the onchip_ram even bursting capable? I don't think so. i cant see any bustcount signals.
    KennyT_altera
    Yes, it is supported. you can't see the burst count because the screenshot does not show the whole waveforms. You can try run the design attached to see it.
  • sadad's avatar
    sadad
    in your design i could not see any burst signals to the onchip ram in the qsys schematic view , so i think there will be a bursting adapter in your interconnect.
    => would you show me a screenshot of your qsys schematic
    KennyT_altera
    Yes, it should be on the bursting adapter. You can check where does the adapter being inserted in the qsys.
    in qsys -> press system -> show system with interconnect -> memory mapped interconnect
    You can also explore what it have under system with interconnect.
