GerhardCadek's avatar
GerhardCadek
4 months ago
Triple-Speed Ethernet IP for Agilex 5 fails during Quartus Synthesis
I am using the IP core version 12.0.0. of the Triple-Speed Ethernet IP in the configuration PCS only with LVDS "transceivers" & HPS adapter. The target FPGA is an Agilex 5 namely the  A5ED043AB32AE3V. The IP core issues an error during Analysis & Synthesis in Quartus Pro 2026.1.
Error(18842): The ENABLE port on clock gate i_altera_pcs_pma_1g_hps|eth_tse_0|hps_gmii_adapter_instance|u_pcs_rx_clk_gated|altclkctrl_comp|altclkctrl_inst|clkena_inst is connected to a constant. It must be driven by a real signal.
I checked the generated netlists. The error occurs in an encrypted section; thus I can not change anything. The usage of the IP core is straight forward. Connect to the Platform Designer project of the HPS, where I fed out EMAC0.
There is nothing I can change during generation of the IP core nor its instantiation. For me this looks like (another) Agilex 5 bug.
Gerhard
  • GerhardCadek's avatar
    GerhardCadek
    I recently learned this forum is now the Altera "support". Now, I reported an issue with an Altera IP core generated by Quartus that fails Synthesis. And there is no answer nor suggestion on that? Really? If you provide me/us the unecnrypted net list we will help ourself and correct the error.
    Gerhard
    GerhardCadek
    thank you for your response. Yes that reference design is exactly what I am doing in my design here. I generated the TSE PCS/PMA IP core for the target device with the HPS bridge and connected it to the exported EMAC0 signals. I traced the IP core source down to the file where the error is reported. Unfortunately this file is encrypted so I cannot read it nor apply a patch there. I can try to reduce my design to just HPS with EMAC export and the PCS/PMA IP core and provide you a quartus archive if this helps you to trace the issue.
    Best regards
    Gerhard
Recent Discussions
