sadad
7 years agoAvalon Interconnect Dynamic Bus Sizing and Bursts
Hello! My Avalon-MM master has 32bit data width and is bursting capable. Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable. Will a 32bit read or write access to ...
KennyT_altera
7 years agoI forgot to mention I did not pull in the ram module in the simulation, you will have to add it to the *.do file before run -a. Here is the screenshot, the current test is the readata is 16bits while the write data at the master is 32bits.
