sadad
7 years agoAvalon Interconnect Dynamic Bus Sizing and Bursts
Hello! My Avalon-MM master has 32bit data width and is bursting capable. Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable. Will a 32bit read or write access to ...
KennyT_altera
7 years agoYes, it should be on the bursting adapter. You can check where does the adapter being inserted in the qsys.
in qsys -> press system -> show system with interconnect -> memory mapped interconnect
You can also explore what it have under system with interconnect.
