sadad
7 years agoAvalon Interconnect Dynamic Bus Sizing and Bursts
Hello! My Avalon-MM master has 32bit data width and is bursting capable. Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable. Will a 32bit read or write access to ...
KennyT_altera
7 years agoYes, it is supported. you can't see the burst count because the screenshot does not show the whole waveforms. You can try run the design attached to see it.
