15 years ago
ALT2GXB Help................
I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board...
I configured the GXB using the Mega core from the quartus...
When I run the GXB on the hardware the recieved data is different from the transmitted data..
Actually I gave the output of the counter(16bit counter running at 312.5MHz) as the transmitter input to the GXB....
I used the Locations as G1,G4 in the FPGA as the RXDATA & TXDATA (serial lines) connected to the HSMA TX_P3 & HSMA_RX_P3 pair....
I have attached the BDF file that I used as my design.Also the CSV file obtained while running the Signal tap II analyser....
DO i have missed anything while configuring the ALT2GXB.....
Santosh
