15 years agoALT2GXB Help................
Hi, I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board... I configured the GXB using the Mega core from the quartus... When I run the GXB on the hardware the recieved dat...
15 years agoDear Sir,
Thank you very much for the reply.......... I want to know how to make the receiver being aligned to the txdata for the first time... can you suggest some documents which can guide more about this alignment.......... --- Quote Start --- I didn't look at your design files, but I'll tell you what you should have. The TX-to-RX path is serial, so whatever you send in parallel at the transmitter can be misaligned by any number of bits when received at the receiver. The receivers have word-alignment and bit-slipping controls. You need to first use those to align the receiver to your transmitted 8-bit/16-bit/32-bit data, and only then will your transmit data and receive data match. For example, you could send the static pattern ABCDh, and bit-slip at the receiver until you start receiving ABCDh, and then you would switch the transmitter to your counter. Cheers, Dave --- Quote End ---
