15 years agoALT2GXB Help................
Hi, I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board... I configured the GXB using the Mega core from the quartus... When I run the GXB on the hardware the recieved dat...
15 years ago --- Quote Start --- I guess if we use only HSMC connectors, we can't characterize transceiver using the transceiver tool kit of quartus.... right......... --- Quote End --- Why do you think that? What do you want to characterize? If you want to probe signals with an oscilloscope, you can do that on the BGA vias. But that does not really tell you much at high frequencies, unless you have a fancy scope with equivalent equalizer settings. Cheers, Dave
