15 years agoALT2GXB Help................
Hi, I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board... I configured the GXB using the Mega core from the quartus... When I run the GXB on the hardware the recieved dat...
15 years ago --- Quote Start --- Do the transceiver tool kit available in the quartus II is applicable to the Stratix II GX devices also ??? --- Quote End --- I am not using the Stratix II GX, so I do not know. However, for the Stratix IV devices, it was not particularly difficult to implement the same functionality directly; using Avalon interfaces in the hardware and System Console Tcl scripts for access. --- Quote Start --- Can we characterize the transceiver features when we are using the transceivers along with the HSMC loopback connections......... --- Quote End --- Sure. Samtec also sell HSMC-to-SMA adapters for about $500 each. They're useful for interfacing to different boards, and they allow you to test links with DC blocks etc. Cheers, Dave
