15 years agoALT2GXB Help................
Hi, I am using the ALT2GXB with the Stratix II GX ep2sgx90ff1508c3 board... I configured the GXB using the Mega core from the quartus... When I run the GXB on the hardware the recieved dat...
15 years agoHi
I am doing a project on the serial communication using the transceivers present in the Stratix II GX ep2sgx90ff1508c3 For this i am using the HSMC connector slot available on the board for the loopback operation. SO now I have 6 TX-RX channels on HSMA & 4 TX-RX channels on HSMB connections.. If I insert the HSMC cards(connectors) that is attached here in the HSMC slot the loopback operation should work properly right??? Or if any other hardware need to be connected like cables to HSMC connectors as told in the High Speed Mezzanine Card (HSMC) Specification link:www.altera.com/literature/ds/hsmc_spec.pdf ??? Apart from assigning the TXDATA & RXDATA pin locations that are available on the HSMC connectors any other signals should be assigned while doing pin assignment. I only assigned the TXDATA & RXDATA pin locations thats it.... Should I assigned the signals like HSMA_CLK_IN0,JTAG_TDO,JTAG_TMS,HSMA_D0-D3,HSMA_JTAG_TDO,JTAG_TCK,HSMA_SDA.... I am new to the HSMC connectors please any one who knows about it ........ please reply.......
